Shadow Catcher in Default Project
In iClone 7, each embedded default project contains an invisible shadow catcher. It can be used to blend in with the background image. A shadow catcher prop can be used to save the time it takes to create a shadow receiving floor plane
To show or hide the dummy object, you can press Ctrl+D or toggle the visibility via Project Settings panel > Display section > Dummy Object check box.
