Using Light Tool
In the Light Tool library, you can find several props with lights attached. These lights operate via Lua scripting language which gives each light an individual control menu. You do not need to touch the Modify panel to adjust the basic settings for the light, such as the color or strength.
Using the Light Tool
  1. Apply one of the props from the Light Tool library. A control menu for the attached light will shown at the top-right corner of the preview window.
  2. Click the Play button to start playing the project.
  3. When the project is playing, use the Control Menu to adjust the light.
  4. The changing will be instantly recorded into the tracks of the light, including the Transform, Color, Multiplier and Parameter tracks.
  5. Play back again to view the recorded result.
