Editing Weight Map
After you have loaded a grayscale image as a Weight Map, you can further edit your weight map by following the steps below:
Basic Editing
The basic editing method is to simply change the Brightness or Contrast value of the Weight Map to adjust the surfaces that are influenced by the soft cloth settings.
  1. Prepare a prop.
  2. Follow the same steps as described in the Loading Weight Map section to load a white image as a Weight Map to the soft cloth.
  3. Play back to see the result.
  4. You may use the Brightness and Contrast sliders to do quick and basic editing for the Weight Map texture.
  5. Play back to see the simulation result.
Advanced Editing
  1. Prepare a prop. In this case, the prop is a plane with Diffuse and Opacity maps.
    The soft cloth will fall onto the ground instantly
  3. In the Edit Weight Map panel, select either the Diffuse or Opacity channel.
  4. Click the Launch button. The selected image in the channel will be passed and open with your favorite image editor (in this case, the opacity image is used for reference).
    Please notice that the marked in circle area on the Weight Map shall be paint in black in order to be pined.
  5. Go back to the Edit Weight Map panel in iClone, click on the Edit Weight Map channel. Click the Launch button to open it in the image editor. It is completely white by default.
  6. Use the Diffuse or Opacity images as a reference. Paint on the Weight Map image with grayscale color.
  7. Save the image in the image editor. The editing result will be automatically sent back to iClone and update the Weight Map data for the soft cloth.
  8. Play back to view the simulation result. The black points hold the prop in the air instead of letting it fall on the ground.
