The Main Concept of Using Alembic
The main concept of using Alembic file involves with two aspects, animations and textures.
You need to individually export animations (in abc format) and textures, and then composite them together in your favorite 3D tools such as 3ds Max, Maya, HitFilm and so on.
The reason to do so is so that an ABC file contains only animation data of vertex and meshes, without packing the necessary textures in order to ensure the minimum size of itself.
Step 1: Exporting ABC file
In iClone, select the desired object whose animations is about to be exported, then export the sequenced and posed “clay statues” made by the vertex and meshes frame by frame into a single file (*.abc).
Step 2: Acquiring Textures
Use 3DXchange to export FBX and FBM of the selected objects because FBX contains the material details.
Step 3: Integrating ABC with Textures
Mapping the textures to the animated meshes of Alembic in the 3D editors.
