User Interface Introduction for GI
The overall visual adjustments for the GI can be done in the Global Illumination tab on the Visual panel.
Global Illumination Section
Global Illumination
This box is the main switch for the GI feature. Activate this box in order to enable the GI effect for both real-time and final rendering. You can also click the leftmost button on the GI toolbar for turning GI on or off.
Ambient Light Color
Click to open the color swatch for setting the main ambient light for the entire project. It is synchronized with the Ambient Light Color in the Visual panel > Atmosphere tab > Ambient Light section.
Ambient Strength
Use this slider to determine the strength of the ambient light effect.
View GI Anchor Buttons
Use these two buttons to show or hide the GI Anchor.
Anchor Settings
Click this button to open the Modify panel and display the sections for setting the GI anchor.
Diffuse Section
Bounce Strength
The intensity of the GI effect on the mesh surface of the scene objects.
Note: This setting is key-able on timeline.
Shadow Details
Creates more contrast in Diffuse under darker areas so that shadows become darker and richer.
Shadow Bias
This setting can resolve shadow blotching by cohesively blurring its disparate patches.
Voxel Cones
The number of light rays emitted per voxel. Higher values equate to better quality at the expense of performance.
The maximum for number of cones is limited to 64.
Multi-Bounce Scale
The intensity of the bouncing lights. Indirect lights do not bounce multiple times if this setting is turned off. Do not increase this value suddenly otherwise the bounce rate can become over-powering causing the scene to over-expose.
Specular Section
Bounce Strength
The intensity of GI effect on Specular or PBR shaders. This parameter is key-able.
Highlight Details
Render darker areas of the Specular shader with more contrast.
Shadow Bias
Resolves the blurry artifacts of the Specular shader.
Noise Effect
Adds noise to reflective surfaces effect by GI for increased realism.
