Saving Attached Lights
You can add an infinite number of lights in your scene. This allows for endless combinations of more detailed and complex lighting schemes, both for interior and exterior use. Moreover, You can be creative with developing your own lighting assets. Simply attach any light to your objects and start building your own custom light library for re-using them in different projects or sharing with others.
Prepare a prop.
Go to the Create >> Light menu and create light according to the type of the prop.
In this case, the Spotlight is created.
Adjust the parameters of the light, including the transformation, strength, color and so on, in the Modify panel.
Right click on the light, execute the Attach command and then click on the prop
to take it as the parent for the light to attach.
Transform the prop and the light will be transformed along the prop.
Make sure the prop is selected and click the Add button under the
Content Manager to add the prop with the attached light into the
Prop custom library.
Note:Please note that you must switch the Content Manager to Set category before click the Add button.
