Prop Picking Path
Props can pick a target path after a path is created in the scene. This simple technique allows you to save time by creating key frame by key frame.
Create a path and add a prop to the scene.
Select the prop and click the Pick Path button in the prop's modify
panel.
Select the path for the prop to attach to.
Before
After
The path name in here represents the path that the prop is currently
attached to.
Note:A link relationship between paths and props and characters will only be established when you use Pick Path. When you direct the character to a certain position using the Move command, a link will not be created.
