Utilizing Point Lights
In the following example, the candle flame is actually a prop mapped with a glow texture; it does not
give off real light at all. We will locate a Point Light at the same place as the prop to
imitate the candlelight.
The original appearance of the project
- Click the Create >> Light >> Point Light command on the main menu bar to add a point light.
- Select the Point Light in the Scene Manger, and move it in the 3D viewer to the correct position.
- Go to the Light section in the Modify panel.
- Change the color of the light.
Adjust the Range and/or
Decay to specify the effect
of the point light.
