Creating Path by Mouse Clicking
The most common method for creating a path is by clicking with the mouse button. the mouse button. Please follow the steps below:
Access the Create menu >> Create Path command.
If there is already a path selected, then you can create another new path be clicking the Create Path button on the Modify panel.
The cursor will turn into a crosshair overlapping on a control point. -
Click the left mouse button to set the start point of the path.
- Move mouse away and a curve will be formed.
- Click again to set a control point.
- Move mouse away and click repeatedly to draw an ideal shape of the path.
- When you want to finish drawing, click with the right mouse button or press the ESC key on the keyboard. A new path is then created.
Creating Path with Straight Lines
Instead of creating curve-based path, you can also create path based of straight lines.
- Click the left mouse button to set the start point of the path.
Press down and hold the Shift key.
- Move mouse away and a straight line will be formed.
