Drag
The Drag setting is effective for singular surfaces; and they only have an obvious effect when the surface moves.
The component of force parallel to the oncoming flow is called Drag. It will essentially pull the soft cloth towards the opposite direction of the initial move.
The moving (M) and dragging (D) directions. |
Drag = 3000 The soft cloth is extended |
You may then mix-up this setting with a Wind force to produce a turbulent and extended soft cloth.
The soft cloth is influenced by Drag and Wind force. |
![Back to Top](../../../Resources/Images/top.png)
