Basic Usage of Bezier Handles
To change the shape of a path, you can either transform the control points belonging to the path, or by using the Bezier Handles without touching the control points.
Create a path.
Select the path and click the Edit Point button on the Modify
panel to go into path edit mode.
Alternatively, you can right-click on the path and choose Path >> Edit Path to enter the path edit mode. - Click on the desired control point. By default, the Bezier Handles
are shown bilaterally.
Note:
You can show or hide the bezier handles for a clear view.
- Click on either one of the red boxes. The transform gizmo will show (if not, press Ctrl + Q to show it).
- Move the box with gizmo to modify the curve's direction.
- Drag the red box away from the control point to increase the curvature.
See Also:
![Back to Top](../../../../Resources/Images/top.png)
