Converting Animation Keys to Path
Here you will learn how to convert random position keys that you set for a prop into a path.
Add a prop into the scene and set some position keys for the prop.
First Key
Second Key
Third Key
Open up the Timeline and select all the Transform keys for the ball.
Right-click on one of the keys and select Convert Position to Path from the right menu.
A path will be created for the selected prop.
Note:
- Once you have converted the prop's position keys to a path, they do not have a linked relationship. A link relation will only be established when you use Pick Path either in the avatar's or prop's modify panel.
- When you convert a camera's position keys to a path, the camera will only follow the control points from point to point and may not follow the curve of the path accurately.
![Back to Top](../../../../Resources/Images/top.png)
