Reducing Color Banding with Noise
In addition to using the Noise effect to eliminate color banding, you can also use Reduce Color Banding with Noise feature provided in the Render panel. Although this setting affects the render, it also influences Real-time Rendering.
Create a project; as you can see there are a lot of color bands or solid colors at the back ground because of the glowing effect.
Open the Render panel and activate the Reduce Color Banding with Noise box in the Render Quality section.
- The color band issues are then eliminated.
![Back to Top](../../../Resources/Images/top.png)
