Creating TTS (Text to Speech) Asset
The TTS technology converts AI-generated responses into speech, allowing avatars to speak with natural voices. The AI Assistant integrated with Microsoft Azure, Google, and ElevenLabs TTS allows you to process and generate text-based responses using advanced AI language models.
Create a New TTS Asset
  1. Navigate to the Go to section near the top-right corner, and click the Third-Party AI Solution and Look-At Graph → button in the Behavior Tree to open the Third-Party Assets Panel.
  2. Click on the Text-to-Speech button to switch to the asset management page.
  3. Select the desired third-party tool from the drop-down list near the bottom-left corner. Currently, the system supports three TTS tools. Select Azure from the options for example.
  4. Input a name for the asset. Click the + button by the side to create a new Azure TTS asset.
    * Alternatively, you can create an empty asset first and rename it later.
  5. The created asset will show in the list above. You can rename or delete an asset by clicking buttons in the entry.
  6. Click on your asset. The configuration settings and options for the asset will display on the right.
TTS Settings
