Spring Settings
When an actor or a prop contains spring effects, you may adjust the spring motion by setting the parameters of the springs.
  1. Select the target object (Actor or Prop).
  2. Access the Spring section in the Attribute tab of the Modify panel.
  3. Select the bone string from the Select Spring drop-down list to adjust its spring effect.
  4. Adjust the sliders to change the spring behavior for the bone string.
