Device Settings - Perception Neuron
Motion LIVE 2D supports the Perception Neuron mocap device in Body mode,
which provides a complete mocap solution for production.
( Watch Tutorial - Connect to Perception Neuron )
- Go to the Perception Neuron official web site, and download and install the Axis Neuron standalone application. Motion LIVE 2D supports all the Perception Neuron Studio, Pro, V2 and V1 editions.
- Make sure that the performer has worn the Perception Neuron devices correctly.
Launch the Axis Neuron, Studio edition for example.
If the Axis Neuron Studio application is installed on another computer within your intranet,
please note down the IP address and Port number shown on the Main Menu > Settings panel for connection with Motion LIVE 2D.
Because Motion LIVE 2D receives mocap data in BVH format,
please make sure the BVH option is enabled in the BVH Broadcasting tab.
Click OK.
Click the Connect
button under the Capturing tab.
Wait for the Axis Neuron Studio (the application) to connect to the Perception Neuron (the device). -
Make sure that the lights on the right side of the application are activated in green, yellow or at least red.
If any of the lights are greyed out, then check the device to make sure it is worn correctly.
- In the Preview window, you will see that the dummy is all messed up.
Before the Axis Neuron receives correct data from the Perception Neuron,
you will need to click the Calibration
button to start the calibration procedure.
Axis Neuron will direct you to do three poses for calibration.
Click the Start button to start to calibrate. -
Have the performer hold the poses on the screen for each phase of the calibration and wait until Axis Neuron finishes the countdown.
Now the dummy in the Preview window stands up and your motions can be correctly received from the Axis Neuron.
- If you encounter a lagging issue during the mocap,
please try to lower the frame rate of Perception Neuron to ensure a smoother capture frame rate.
