Name
Description
File
To create an empty project, save or open a CrazyTalk Animator project file (*.ctProject).
To switch to the character or prop Composer Mode.
To convert between props and scene objects.
To import a CrazyTalk Animator model (*.ctActor)
or character animation (*,ctMotion, *.ctPerform, *.ctFcs, *.ct3DMotion, *.iMotion)
or prop motion (*.ctAnim).
(Only Pipeline version can support *.iMotion)
Edit
To undo (Ctrl + Z) or redo (Ctrl + Y) the last operation.
To select or duplicate characters, props or objects.
To set flip, link, visible or opacity keys to the selected characters, props or objects.
To perform Timeline commands (loop, speed, break) or
set the 3D motion options, align angle, extend clip length for the selected Motion Clip.
To adjust the 3D motion settings for the selected actor.
To invoke the Project Settings and Preference panels.
3
Create
To create the actor face from an image file (*.jpg, *.png, *.bmp).
To load the media material for props, image layers or background from
image files (*.jpg, *.jpeg, *.bmp, *.gif, *.png, *.tga, *.gif) or
video files (*.avi, *.wmv, *.rm, *.rmvb, *.mpeg, *.mpg, *.mpe, *.mp4, *.asf, *.asx, *.wm, *.flv, *.mov, *.popvideo, *.swf).
To import sounds or background music from an audio file (*.wav, *.mp3).
To create a script for the selected actor by recording voice, Text-to-Speech Editor, loading an audio file (*.wav, *.mp3)
or CrazyTalk script file (*.ctFcs, *.cts, *.clp, *.ct7script, *.ct7motion).
To launch the Render Style and Runtime Composer panels.
4
Animation
To launch the Action Menu, Action Menu Editor, Sprite Editor,
or Layer Editor panel for the selected actor, prop, or object.
To launch the 2D Motion Key Editor, 3D Motion Key Editor, Puppet Editor, Motion Key Editor,
and Lips Editor panels for the selected actor.
To show the Prop Key Editor on the Property Tool Bar for the selected sprite of the prop.
To launch the Text Editor or Sound Modify panel.
To set keys for the selected prop or scene object on the Property Tool Bar.
To add keys on the selected track (Transform, Flip, Facial Layer, Face Motion)
(Pipeline and Pro only),
or set a transform key for the object back to the origin size and position (0,0,0) of the scene.
To align the selected motion clip data (root, head, right/left hand, or right/left leg) to the previous clip.
To insert extra frames to the current project or add flags in the Collect Clip track of Project on the Timeline.
To remove motion clips of the selected actor or remove all animation data in the current project.
5
Control
To perform Play Bar commands, playback, pause, stop, or jump to the start, end, previous or next frame.
To turn on/off the voice or music volume in the current project.
To snap the 3D motion angle to the previous motion clip.
To snap the object movements to the grid line.
To toggle to orthographic camera or enter the camera record mode.
To enter the Camera Record Mode.
6
Render
To preview the output image of the current frame.
To export the current project as audio, video or image files.
7
View
To show/hide the on-screen display (FPS, grid line, world axis, stage/composer mode display).
To enter the full screen mode (F11 and F12).
Full Screen Mode: To enter the full screen mode while showing the
safe area.
Full Screen Mode w/o Safe Area: To enter the full screen mode while hiding the
safe area.
To perform the Camera Tool Bar commands, zoom in/out of the scene, pan or rotate the camera,
switch to the different view modes of the camera, or enter the 3D view mode.
8
Window
To restore all the tool bars and panels to the default docking places.
To show/hide the tool bars, Timeline, Content Manager and Scene Manager panels.
9
Help
To launch the Help document, go to the official web page for demo videos or tutorials,
or view the product FAQs and get further assistance.
To login with the member account.
To check for available program updates.
To access the City Marketplace of CrazyTalk Animator.
To get free bonus content or purchase trial content.
To activate the content you have paid for or verify all of your content in the Template and Custom libraries.
To access the home page of Reallusion or CrazyTalk Animator.
To show the product information for CrazyTalk Animator.
Name
Description
File
To import a CrazyTalk Animator actor file (*.ctActor)
or save the current actor as a CrazyTalk Animator actor file (*.ctActor).
To switch back to the Stage Mode.
Edit
To select sprites, attach props to sprites.
To add joint masks and switch the color of joint masks.
To show/hide or snap connect points.
To launch an external editor to modify the created face image of the actor.
To activate actor 3D motion settings.
To launch the Preference panel.
3
Modify
To load an actor swf file.
To enhance the actor details on sprite layers and joint masks.
To launch the Confirm Multi-angle Settings, Actor Proportion,
Render Style and Sprite Editor panels.
To carry out face or body calibration and launch the Calibration panel.
4
Face Editor
To load an image file (*.jpg, *.png, *.bmp) to create a new face for the current actor.
To adjust the color of the face image,
fine tune the face fitting result and the face angle.
To modify the applied eyes and teeth templates, or customize the eyes and teeth for your actor.
5
View
switch to the different view modes of the camera.
6
Window
To show/hide the tool bars, Content Manager and Scene Manager panels.
7
Help
To check for available program update.
To get free bonus content or buy all trial content.
Name
Description
File
To import a CrazyTalk Animator prop file (*.ctProp).
Edit
To select props, or attach more props to a prop.
To launch an external editor to modify the selected prop.
3
Modify
To launch the Render Style and Sprite Editor panels.
4
View
5
Window
6
Help
To get free bonus contents or buy all trial contents.
To activate the contents you have paid or verify all of your contents in the Template and Custom libraries.
