Set the Scene Undo to decide how many actions you can Undo/Redo. The maximum is 99. A higher value requires more resources of your system.
This setting decides the resolution rendered in the working area. If you encounter a blurry result, especially with image-based items, then try to increase the value of this setting to render the working area in higher resolution.
Low |
Mid |
High |
The temp folder is a folder for temporary files created by CrazyTalk Animator during operation. You can define where temporary files are saved in the preferences settings.
Click the Open
button in the Temp Folder option and browse to a folder you wish to use as the temp folder.
Make sure the hard disk the temp folder is located in has sufficient free space, especially when you are using CrazyTalk Animator to produce high resolution videos.
You can select an external application for use as a texture editor with CrazyTalk Animator. Textures edited using the "Launch" feature of the CrazyTalk Animator material editor will open with the image editor selected in this section. (e.g. Adobe Photoshop)
Click the Open
button in
the Texture Editor option and browse to the executable
file of a suitable texture editor application.
When you click the
Launch External Image Editor button in the composer to
edit the image-based elements in a sprite,
you are allowed to decide the way the image is opened in the external editor.
