1. 3D View
The dummy in the 3D view displays the character's current 3D pose. You may Double Click
on a body part to select it.
2. 3D Toolbar
The 3D tools in the bar can be used to control the direction of
the 3D view and move or rotate the body part.
Camera Tools
Home: Reset to the initial angle of the 3D view.
Zoom (Mouse wheel or Alt + Right +
Left-mouse-buttons drag in 3D view): Zoom in or out the 3D view.
Pan (Alt + Drag in 3D view): Hover the 3D view around.
Rotate (Alt + Right-mouse-button drag in 3D view): Rotate the 3D view around the dummy.
IK or FK Tools
Move (IK): Move the selected body part (bone).
Rotate (FK): Rotate the selected body part (bone).
3. Angle Slider
Drag the slider to determine the angles of the
G2 character. You can also add 3D angle keys by dragging to
different angles in different times to
turn the character.
4. Keying Mode
You may choose the radio button to determine if the chain reaction applies to
only the limbs or the entire body.
Full Body: When you move any body part, it maybe drives the torso part to move along.
Body Part: If you only want to move the limbs or head, then choose this radio button.
The original pose of the character.
Choose Body Part and drag the hand, only the limb is influenced.
Choose Full Body and drag the hand, the entire character can be
influenced and moves along.
5. Pinning Status
When you are editing a body part, the locking status of other ones
can be defined in this section.
Please refer to the Locking Bones
section for more information.
6. Mirror
Activate this box so that you may simultaneously adjust the same body
parts from both sides.
7. Reset / Default
Click these two buttons to retrieve pose. Please refer to the
Setting Default Keys and Resetting Motion Layer Keys section for more information.
8. Dummy Pane
Select one of the body parts to offset the
corresponding bones.
Icons:
: A selected
body part.
You may use it to lock the corresponding body part or
move the body part to offset the corresponding body part.
: A free
body part.
Auto-update the location and orientation of the corresponding body part when you are
editing another body part.
: A move-locked
body part.
It causes the corresponding body part not to move when you are
: A rotate-locked
body part.
It causes the corresponding body part not to rotate when you are
: A locked
body part.
It causes the corresponding body part not to move nor rotate when you are
: A quick lock.
Use it to quickly lock or unlock the T and R
of the corresponding body part.
Please refer to the
Locking Bones section for more information.
