In Pose mode, you can only set the pose to characters. If you need to adjust detailed body parts, then switch to
Body mode in order to fine-tune each body part with exact values.
Enlarge to Create Visual Space Sensations
Although characters in CrazyTalk Animator are flat (2D view), you can always change body sizes to create a visual space sensation.
Select a character and open the Body Key Editor.
Set a pose.
Pick individual body parts and change the size of each one.
Click the 3D View button to view this character.
Although the character appears to have a visual space sensation, it is still actually flat.
Stretching Animation
Set the character's pose in the Pose mode.
When the Body Key Editor appears,
switch to Body mode.
The dummy pane will change to a detailed one.
Click one of the body parts, on the dummy pane, or click the part directly on the
character. A transform handle box will appear around the body part.
Un-proportionally scale the selected body part.
Please note that the child node (the shoe in this case) will also be affected.
Modify the child node in the same manner, to get the best results.
Transform Tool
If you need to set a transform key with an exact value,
then select the body part and adjust the parameters on the Property Tool Bar.
X, Y: Enter these values to decide the location of the body part.
W, H: Enter these values to decide the Width and the Height of the body part.
Lock/Unlock Ratio: Click this button to toggle the Keep Aspect Ratio on/off.
R:
Enter a value to determine the orientation of the body part.
Mirror:
Activate this box and choose Forward or Reverse
from the drop-down list to simultaneously adjust symmetric limbs.
Choose Forward to cause both limbs to transform in the same direction or orientation.
Choose Reverse to cause both limbs to transform in opposite directions or orientations.
Click these buttons to perform a horizontal or vertical skew of the body part in order to fix body stretch or distortion issues.
Vertical Skew Up:
Click this button to skew the body part upward in 5-degree increments.
Vertical Skew Down:
Click this button to skew the body part downward in 5-degree increments.
Horizontal Skew Left:
Click this button to skew the body part leftward in 5-degree increments.
Horizontal Skew Right:
Click this button to skew the body part rightward in 5-degree increments.
Note:
Transforming body parts will set transform keys in the Body_Transform track under the Motion main track
and T sub tracks that belong to that particular body part.
Detaching Animation
In addition to editing the size, you may also move the body parts away in order to create a detaching animation.
Select a character and open the Body Key Editor panel.
Go to a desired time frame where a body part starts to detach from
the character and set a pose.
Go to another time frame and move the body part away (You may optionally resize the body part).
Note:
If your character's head is sprite-based,
then you can switch to Face mode to change the body dummy pane to the face dummy pane.
Please refer to the
Using Face Mode - Facial Features
section for more information.
