Wave Settings
Move
- Adjust the numeric fields or drag the triangles to set the
ranges for the x-, y-, and z-axis.
- The Min and Max numbers are, by default, identical numbers of positive and negative.
- Click up the Lock in order to set the Min and Max number in different values.
- Set the Space to World or Local coordinate for the object to offsets.
Rotate
- Adjust the numeric fields or drag the triangles to set angles
for the rotation angles.
Scale
- Adjust the numeric fields or drag the triangles to set the ranges for the W (width) and H (height).
- Activate the Lock Ratio checkbox for uniform
scale.
Common Settings for Move, Rotate and Scale Amplitudes
- Tween:
The Tween setting can be set to "Linear", "Noise", "Random Cyclic" or "Step".
Play the following video to view the movement patterns for different tween options. - Loop Duration (Frames):
Set the Loop Duration (Frames) as the length for each wave in frames. You can consider it as the interval length for each wave.
