Fine Tuning the Motions with IK, FK
This section covers how to fine tune the actor with IK (Inverse Kinematics) and FK (Forward Kinematics).
![Closed](../../../../../Skins/Default/Stylesheets/Images/transparent.gif)
IK, Inverse Kinematics, refers to a process utilized in computer graphic animation. In this process, the parameters of each articulation, in a jointed flexible object (a kinematic chain), will be automatically calculated to achieve a desired pose, especially when the end point moves.
Basically speaking, IK is how the child node, as it moves, affects all the parents' position and orientation values.
Child node selected |
Offsets of all nodes in the chain gets affected |
Before you utilize IK to animate your actor, be sure that you have opened the 3D Motion Key Editor.
- Double click on the target actor.
Click the
3D Motion Key Editor button. Alternatively, you may right click on the desired actor and select Motion Menu >> Edit Motion.
Change to the
tool in the 3D Toolbar.
Select a body part (in this case, the right hand) by double clicking it on the dummy in the 3D view or by
simply clicking it on the dummy graphic.
Drag the axis of the gizmo on the 3D view.
FK, Forward Kinematics, is how the positions of particular parts of a model at a specified time are calculated from the position and orientation, together with any information on them of an articulated model.
To sum up, FK refers to the effect on the child nodes as the parent moves or rotates.
Parent node selected |
Only parent's offset gets affected |
Before you utilize FK to animate your actor, be sure that you have opened the 3D Motion Key Editor.
Click the
Change to the
Select a body part (in this case, the upper body) by double clicking it on the dummy in the 3D view or by
![Back to Top](../../../Images/UI_Icons/top.png)
