Introducing the 3D Motion Key Editor
1. 3D View |
The dummy in the 3D view displays the character's current 3D pose. You may Double Click on a body part to select it. |
The 3D tools in the bar can be used to control the direction of
the 3D view and move or rotate the body part.
IK or FK Tools |
3. Angle Slider |
Drag the slider to determine the angles of the G2 character. You can also add 3D angle keys by dragging to different angles in different times to turn the character. |
4. Keying Mode
You may choose the radio button to determine if the chain reaction applies to only the limbs or the entire body.
5. Pinning Status
When you are editing a body part, the locking status of other ones
can be defined in this section. |
6. Mirror
Activate this box so that you may simultaneously adjust the same body parts from both sides. |
7. Reset / Default
Click these two buttons to retrieve pose. Please refer to the Setting Default Keys and Resetting Motion Layer Keys section for more information. |
8. Dummy Pane |
![Back to Top](../../../Images/UI_Icons/top.png)
