Gizmo of Objects in Preview Window
The Character Creator Preview window provides a visible gizmo to handle and modify the RTS (Rotate, Transform, and Scale) parameters of the selected object. Characters including CC Avatar, Humanoid, and Creature can be moved and rotated with the gizmo, but scaling should be done with the proportion tool.
The Gizmo mode can be enabled within the Preference panel.
Rotate
Drag the three circles around the object to rotate it along the 3 axes.
Transform
Drag the handles to move the object along the 3 axes.
You can also drag the square at the corner to move the object on the planes of two perpendicular axes.
Scale
Drag the handles to scale the object along the 3 axes.
You can also drag the yellow cube in the center of the gizmo to scale the object at a uniform ratio.
