System Section
Undo Times
Set the Undo times to decide how many actions you can Undo/Redo. The maximum is 180. Higher values require more system resources.
Temp Folder
The temp folder is a folder for temporary files created by Character Creator during its usage. You can define where temporary files are saved in the preference settings.
Click the Choose
button in the Temp Folder option and browse to a folder you wish to use as the temp folder.
Make sure the hard disk the temp folder is located on has sufficient free space especially when you are using Character Creator to produce high resolution images.
Texture Editor
The texture editor should be set to your go-to image editor. It is used to show the UV reference map for creating custom texture images.
Scene Mode
The Scene Mode drop down list determines if the floor is shown or hidden when you create a new project or apply a new character.
