Creating Morphing Slider for External Characters
In this section, you can create a slider without even opening the source or target morphs, as they are both external files.
Prepare a source character file iAvatar format.
Prepare a target character file in OBJ or
iAvatar format.
Note:To keep DRM protection, the OBJ file for the target character must be prepared with its corresponding checksum data file.
Launch Character Creator. Execute Character > Load Neutral Base > CC3+ to load a neutral character.
Perform Create menu > Morph Slider Editor to open the
Morph Slider Editor.
Name the slider and add a path.
Note:Please refer to the point 1 in the User Interface Introduction for Morph Slider Editor section for more information.
Set the Morph Value > Minimum to 0 and the Maximum to 100, so that when the custom slider is set to maximum,
the character retains its original look.
To create a thumbnail, click the
button and
load
an existing image.
In the Source Morph radio button group, choose the File radio button to load the
source character prepared in step 1 by clicking the
button.
In the Target Morph radio button group, choose the File
radio button and load the character prepared in
step 2 by clicking the
button.
Click the OK button to add your custom morph slider into
the designated node
and path.
Note:Now, if you drag the slider, you will see the female character gradually deform because the source character is not loaded.
Value = 50
Value = 100
In order to view the correct result, you need to first load the source character into
Character Creator.
Drag the newly created slider to see the morph in action.
Value = 50
Value = 100
