Modifying Existing Accessory
In addition to using embedded accessory templates, you are allowed to generate custom accessory by modifying the existing accessory with your preferred 3D tools.
Create a new project and create a character with accessory.
Execute File > Export to FBX > Clothed Character.
Note:To learn more, see Exporting FBX Characters.
- Click the Export button to export the character in FBX format. You will get FBX and FBXKey files.
Open the FBX file in your preferred 3D tool.
Modify the accessory with the features provided in your 3D tools.
Note:- For Character: Subdivided characters will be properly handled when the original FBX key is loaded into Character Creator along with the FBX character.
- For Accessory: Editing without changing the topology or deleting faces can be done with 3rd-party 3D tools. However, if you increase or decrease the faces using smoothing, subdivision, or deletion, then you must rebind to the bones manually.
