The Settings for Importing Designed Hair
Create Assets Panel
- Import Clothed Character: This field displays the FBX character you have modified and exported from 3D tools.
- Decrypt Key File: You must include the *.fbxkey file you have created
in the step in order to authenticate the assets into Character Creator.
Note:You will get an *.fbx and a *.fbxkey files when you export FBX from Character Creator.
The information included in the FBX Key file include:
- DRM Base Content Information.
- Meta Data:
- Bone Scale: The size of each bone of the character.
- Body Skin Weights: The skin weight for each vertex on the character.
- Cloth Type: The type (cloth, gloves or shoes) of the clothes meshes.
You must load the FBX KEY file when you import a FBX character from other 3D tools to ensure the correctness of the shape of the body and the hair.
- Nude Template for Gloves and Shoes: If one has modified the sizes or shapes of the hands or feet in a 3D tool (highly recommended to be done in Character Creator instead of your 3D tools), then you must activate this box and load the adjusted nude and bone-skinned character (in FBX format) as the reference for the floor contact feature. You do not have to activate it if you are creating hair.
Asset Import Status Report
If the loaded FBX contains customized hair you made, then there
will be Hair item in the Type
drop-down list for the hair mesh.
- The layer number is for Clothes but not for Hair. You do not need to do any setting.
