Increasing Light Contrast with Multiplier
In Character Creator, the strength of each light is specified by the color. When you want to increase the strength and contrast of the light, you may de-saturate the color of the light to make the entire scene lighter in color.
By using the Multiplier feature of the light, you are allowed to keep the original color of the light while increasing the global strength and contrast. This feature applies to Directional Lights, Spotlights, and Point Lights.
Producing Lighting at Noon with the Multiplier
Prepare a project with two default lights.
Select one of the the lights in the Scene Manager and go to the
Light section in the Modify panel.
Change the light color to green.
Increase the light strength by adding values to the Multiplier.
Multiplier = 2.5
The light is brighter while the color of the light remains the same.
Multiplier = 9.99
The light is brighter and stronger.
Note:Please refer to the Darkening the Shadow section for more information.
Multiplier, Spotlight and Point Light
With the same concept, you may use the Multiplier to emphasize the beam cast by the spotlight or point light.
- Spotlight
The spotlight effect is dramatized after the Multiplier is increased to 3.
- Point Light
The point light effect is dramatized after the Multiplier is increased to 3.
