Building Scene with Props
Character Creator provides abundant prop contents for you to quickly build up your scene. However, you can also build up the scene with embedded 3D blocks.
Prop Library
There are different sub folders under the Stage Element >> Prop library in which you can apply different props onto the stage.
Apply from Libraries
- 01_Board Light: You can use the prop in this library as light when GI is enabled.
They can be taken as the lighting in a studio.
- 02_Reflector: These props can be used to reflect light when GI is turned on.
Adjust the material settings of the reflector to reflect desired light effect to the scene.
- 03_Backplane: You can use the backplane props to create a studio scene.
The light hit the backplane is even and smooth, so are the lights reflected from it. Then can also be used to receive shadows to emphasize the weigh of the objects in the scene.
- 04_Special Light: These props are of special shapes when GI is turned on.
You can use them to create fluorescent lights, ring lights or lights in circle.
- 05_Floor: Use the props in this library to create floor.
The GI light effect, regular lights and shadows are visible on the floor.
- 06_Image Plane: The Image Plane are regular props with scenery images applied on it.
You can use them to crate fake environment by transforming these image planes.
*You can also drag image file into the preview window with right-mouse button held to create an image plane. - 07_Others: There are also miscellaneous props in this library.
The Mask can be used to create dramatic shadow effects on the character.
Apply from iClone Prop Libraries
In addition to the prop libraries in Character Creator, you are allowed to drag and drop props from iClone prop library to vitalize the scene.
You can purchase more prop contents from Reallusion Official Content Store or Marketplace to enrich your Character Creator project.
