Skin Base for Characters
The Skin Base is a layer that constantly sits at the bottom of the layer stack, which gives the character a basic appearance in advance, so that the character is not just a solid white model.
Without Skin Base Layer |
With Skin Base Layer |
You can find the Skin Base layer in each material when you activate the Skin settings in the Appearance Editor.
The deployment of the materials are as shown in the following illustration:
These UV textures map to the newly designed regions for the CC3+ characters. Refer to the Regions of Character Materials section for more information.
You can adjust these Skin Base layers through the settings in the Appearance Editor.
Skin Base Settings for Head Material
Refer to the Settings in Appearance Editor - Head section for more information. -
Skin Base Settings for Body Material
Refer to the Settings in Appearance Editor - Body section for more information. -
Skin Base Settings for Arm Material
Refer to the Settings in Appearance Editor - Arm section for more information. -
Skin Base Settings for Leg material
Refer to the Settings in Appearance Editor - Leg section for more information. -
Skin Base Settings for Nails Material
Refer to the Settings in Appearance Editor - Nails section for more information. -
Skin Base Settings for Eyelash Material
Refer to the Settings in Appearance Editor - Eyelash section for more information.
When you deactivate the Appearance Editor, all the layers will be merged onto the Skin Base and the system will generate texture resources for the texture channels of the corresponding materials in the Material tab.
