The Layers of Makeup
The fundamental makeup is composed of several layers, they are Highlight and Contour, Blushes, Lips and Eye Makeup.
These layers also map to the sections in the Modify panel >> Appearance tab >> Actor >> RL_G6_Body >> Skin_Head >> Cosmetic of Character Creator.
  • Blush: The Blush layer consists of three channels, Contour, Blush and Highlight. You are able to apply different colors to the channels in order to perfect the complexion, which makes the face look healthier.
  • Lips: Use the Lips layer to provide brilliant color that infuses lips with the appearance of moisture and fullness, giving them a more sensual appearance. This section divide lips into four areas defined by Base, Corner, Contour and Highlight channels.
  • Eyeliner: The Eyeliner can be used to accent or re-shape the look of the eyes, in order to highlight the color of the iris or create a base for eye shadow.
  • Eyeshadow: This section is composed of 5 color channels, Base, Shadow, Contour, Highlight and Inner Canthus, which gives an even, ultra-luminous finish; a silky, almost creamy texture that blends perfectly into the eyelid.
