Character Creator provides auto-conforming feature so that when a character's body proportion is changed, the clothes and hair will automatically adjust to conform with the character's body shape.
The original shape of the body, cloth and hair. |
The clothes and hair are auto re-shaped along with the body shape. |
However, in some cases of the clothes or hair, the auto conforming feature can cause undesireable results.
The original shape of the clothes. |
The shapes of the individual elements of the belt are distorted after the clothes is auto-conformed. |
You can follow the steps described in the following section to solve this issue.
*This solution is best used for the hard pieces of the clothes, such as armors, belts with buckles and shields.
To solve the issue described in the illustrations above, you can follow the steps below:
Note: |
Please refer to the Surface Editing section for more details about editing meshes. |
Note: |
If the adjusted shape is not satisfying or if you distort the meshes too much that you want to retrieve the
original conforming result, then activate the Enable Conforming box and click the
Reset to Default button at the bottom of the Conform Clothing panel to retrieve the
auto-conforming result.
