Changing Props Render Style - Basic
For each default vector-based prop, its sprites are well-grouped and is embedded with pre-defined render styles. You may simply select the ideal style and the colors of the sprites simultaneously change.
  1. Apply a default prop and switch to the composer mode.
  2. Click the Render Style button to open the panel.
  3. Click on either of the template to change the render style of the prop.
    Monochrome: This template shows the initial color of the prop sprites.
    Neon: Innovative and experimental fashion style for the prop.
  4. Drag the Weight slider to determine the level of the render style effect on the prop.
    Weight = 100
    Weight = 30
    (the prop color will be closer to the initial color, which is blue)
  5. You can also activate or deactivate the Show Line box to show/hide the contour line of the prop.
    Show Line = On
    Show Line = Off
    Note:
    If you want to create custom groups of the prop's sprites, then refer to the section below for more information (please note that the feature only supported by Pro or Pipeline version):
