Changing Props Render Style - Advanced
In addition to changing the prop's render style by embedded templates, you are able to manually set the render style by pre-defined sprite groups if you are using the CrazyTalk Animator Pro or Pipeline version.
  1. Apply a prop and switch to the composer mode.
  2. Click the Render Style button to open the panel (you may optionally follow the steps in the Changing Props Render Style - Basic section to set the character in different render style).
  3. Click on the Advance Settings button at the bottom right of the panel to show the advanced settings.
  4. Select an item in the Body Part Selection pane.
    Note:
    You may also grouping the sprites for setting render style together. Please refer to the Grouping Sprites for Render Style section for more information.
  5. Drag the Brightness, Contrast, Hue and Saturation sliders to adjust the parts with same group name.
    The initial look of the skin color.
    The color of the parts with same group name are simultaneously adjusted.
    Note:
    Click the Reset button to reset the four sliders to the initial settings of the currently selected template.
  6. If you activate the Invert Color box, then the parts in the same group will be changed to the complementary color.
    The initial look of the cushions color.
    The color is changed to its complementary color.
