The Render Style feature assists you to change the color of grouped sprites once and for all. You are able to group custom poses and angles in sprites for easily adjusting their colors by the use of the Render Style.
*Please note that this feature is for the Pipeline version only.
Prop Composer button.
Apply button at the bottom right of the editor to
assign the group name to the component.|
Note: |
Please note that since the SWF from Flash can be divided into two main
components, Shape and Line, when you are
doing the vector grouping procedure, DO NOT
assign the "shapes" into the Outline group, because
although the color of the shapes are able to be adjusted
with the real lines, they can not be turned off by deactivating the Show Outline.
Make sure you only assign "lines" to Outline group. |
button.
Note: |
The outline is turned off |
The colors of the surfaces are adjusted (Retro style). |
Note: |
Please refer to the sections below for more information: |
