Please open the Dummy_Template_Body.dpa
with DrawPlusX6 (this .dpa file is
within the zip file
that you downloaded earlier) You will see a view that is similar to the picture
below:
The three major parts in DrawPlus are:
1.Stage
2.Layer
3.Element
Properties (Naming Rules)
On the stage, you will see the character in 10 different
angle profiles. These angles must be replaced later on with your own sprite content
when creating a custom character.
In the layer panel, an angle has 4 parts including:
1. Angle name
2. Pivot
3. Pivot Base
4. Sprites
