Using Check Zone Nodes
The Check Zone nodes can be used to verify whether a specific object (character, prop, or MD Prop) enters a zone in order to trigger actions for other objects.
** Please note that this node is best suited for scenarios involving interactions between multiple characters, or between characters and objects (props or MD Props).
  1. Create a project with a characters, a prop and an MD prop.
    The prop has been embedded with a performing animation.
  2. Open the MP Node Graph panel. Right-click on the viewport space and choose Condition Node > Check Zone.
    A new Check Zone node will be inserted on view.
  3. Drag a flow line from the Start node’s output and connect it to the Check Zone node’s input.
  4. Select the node and adjust the settings in the Attributes page.
    • Zone: Specify the target MD Prop for occupation status detection. If you use the dropper tool, click the waypoint marker (the flat disk with double arrows) instead of the model’s mesh.
    • Entity: Select a target object (character, prop, or MD prop) to detect whether it enters the zone range.
    • Target Parts (for multi-element Props and MD Props only): Choose Any or All for the True / False judgment based on multiple crowd occupation points.
      • Any: If any one of the sub-element of the Prop or MD Prop enters the zone, the node outputs True.
      • All: Only when all elements of the prop or MD prop enter the zone, the node outputs True.
  5. Connect events to the outputs of the Check Zone node.
    • True: Connect to a Character node, indicating that the character performs the Mull Over motion when the object enters the zone.
    • False: Connect to a Character node, which causes the character to Look Around when the zone is clear.
  6. Use joints to loop back from the False event for continuous detection.
  7. Create another thread that drives the other object (in this case the prop) to move into the MD Prop's zone.
  8. Start the Go MD Mode to view the animation results.
