Display Section
The settings in this section provide information for your reference during editing. However, this
information can not be seen in the output files.
- Info:
Info displays the FPS (Frames Per Second) and Poly Count(s) of the current project.- FPS: Displays the Frames Per Second information in the 3D viewer.
- Poly Counts: Polygon count information of the
entire project and the selected objects will be shown at the
top-left corner of the preview window.
- World Axis:
When the World Axis box is on, a coordinate displays in the origin. It is very useful when you need to input x, y, z value, or create custom Helper.- Check/Uncheck the World Axis box to show/hide the world axis, or press Ctrl + A to toggle on/off.
The R.G.B. color of the World Axis represent the X, Y, Z direction
(R=X, G=Y, B=Z)
- Message Panel:
Activate / deactivate this box to show / hide the message panel at the right bottom corner of the 3D viewer.
- Show Camera Ratio: Activate this checkbox to show the camera ratio.
- Show All Messages: Activate this checkbox to show all the Startup Message Boxes.
- Safe Frame:
Activate this checkbox to show the safe frame on the 3D viewport. The part outside of the frame will not be included when you render the project to media.- Opacity: Set the
border opacity for the safe frame.
Low safe frame opacity.
High safe frame opacity.
- Overscan: Sets the size of the part outside of the safe frame.
Small overscan value.
Large overscan value.
- Opacity: Set the
