System Section
Undo Times
Set the Undo times to decide how many actions you can Undo/Redo (180 max). A higher value requires more system resources.
Temp Folder
The temp folder is a folder for temporary files created by iClone during operation. You can define where temporary files are saved in the preferences settings.
Click the Choose
button in the Temp Folder option and browse to a folder you wish to use as the temp folder.
- Make sure the hard disk the temp folder is located on has sufficient free space especially when you are using iClone to produce high resolution videos.
Loading files while the temp folder is full will cause the application to crash. File loading will now first check the available free space in the temp folder. For example, if the space available is less than 500 MB, then a message will appear.
Texture Editor
You can select an external application for use as a texture editor with iClone. Textures edited using the "Launch" feature of the iClone material editor will open with the image editor selected in this section. (E.g. Adobe Photoshop)
Click the Choose
button in
the Texture Editor option and browse to the executable
file of a suitable texture editor application.
