Hotkey Manager User Interface
Notice that the action names are in blue while the group names are in white.
Use the Preset drop-down list to choose the desired hotkey-mapping preset.
This preset menu can be used to reset default preset, duplicate, rename, remove, import or export hotkey-mapping presets.
- Reset to Default: Resets all hotkey settings to the factory default ones.
- Duplicate Preset: Duplicates the current hotkey-mapping preset.
- Rename Preset: Used to rename the current hotkey-mapping preset.
- Delete Preset: Deletes the current hotkey-mapping preset.
- Import Preset: Imports a previously saved hotkey-mapping preset.
- Export Preset: Exports the current hotkey-mapping preset and save it as a *.ini file.
You can use this drop-down list to choose the input device and by default, Keyboard.
For choosing Keyboard as the input device, refer to the How to set hotkeys section.
For choosing Gamepad as the input device, refer to the How to set hotkeys with Hotkey Manager section.
The Search Type helps you to search for the desired hotkey-mapping by the Action Name or Key Sequence.
Click these two buttons to Expand or Collapse the mapping list.
