How to merge projects
iClone provides new Merge Projects feature for merging objects in different projects, either partially or completely. Not only does it save a lot of time to recreate identical animation in different projects, but also benefits you by sharing your projects with others. Furthermore, constrained objects in the project will be automatically transferred to ensure correct constraint animations.
- Create a project in which the objects are grouped with Collection feature, take the sofa for example.
- Save the project as an iClone file (*.iProject).
- Create a new file.
- Execute the File > Merge Project command.
- Pick the file saved in step 2 as the source project.
- A Scene Manager pops up in which all the objects in the source project are listed.
- Only activate the desired objects' checkboxes (in this case, the Sofa). Click the Merge button.
- As you can see the selected object(s), collection included, is imported and merged into the current project.
- You can transform the objects afterward.
