Timeline Shortcuts
Refer to the Hotkey Manager section for more information about customizing and editing the hotkeys.
Commands |
Shortcuts |
Description |
Previous Frame |
Left |
Goes to the previous frame. |
Next Frame |
Right |
Goes to the next frame. |
Previous Key |
Ctrl + Left |
Jumps to the previous key. |
Next Key |
Ctrl + Right |
Jumps to the next key. |
Zoom In |
Zooms in the timeline view. |
Zoom Out |
Zooms out the timeline view. |
Fit to Window |
Ctrl + * |
Displays and fits all frames of the entire project into the timeline view. |
Actual Size |
Ctrl + / |
Displays the initial view of the timeline. |
Delete |
Delete |
Deletes keys or clips |
Home |
Home |
Goes to the start frame. |
End |
End |
Goes to the end frame. |
Select (Continuously) Keys |
Shift + LMB drag |
Drag to continuously select keys. |
Select (Continuously) Clips |
Shift + LMB click |
Click to continuously select clips. |
Pan View |
Pan the timeline view left or right. |
Zoom View |
Zoom in or out the timeline view. |
Commands |
Shortcuts |
Description |
Add Key |
A |
Adds a new key. |
Break |
Ctrl + B |
Breaks the selected clip into half. |
Playback Range |
Turn On the Playback Range Flags (yellow). |
Playback Range |
Turn Off the Playback Range Flags (yellow). |
Sound Settings |
8 |
Select a sound clip and press the 8 key to display the Sound Settings panel. |
Loop Clip |
1 |
Loops the clip when it is extended. |
Speed Clip |
2 |
Changes the clip speed when it is extended. |
Resize Clip |
3 |
Resizes the clip when it is extended. |
Motion Direction Control |
4 |
Enters the Motion Direction Control mode for changing the direction of the clip. |
Motion Modifier (for Clip) |
5 |
Launches the Motion Modifier panel. |
Copy Keys/ Clips |
Ctrl + C |
Cut Keys/ Clips |
Ctrl + X |
Pasted Keys/ Clips |
Ctrl + V |
Duplicate Keys / Clips |
Ctrl + LMB Drag |
Duplicates keys or clips. |
Commands |
Shortcuts |
Description |
Lips Editor |
7 |
Launches the Lips Editor. |
Talking Style Editor |
6 |
Launches the Talking Style Editor. |
Next Key |
Ctrl + Right |
Jumps to the next viseme key. |
Previous Key |
Ctrl + Left |
Jumps to the previous viseme key. |
Commands |
Shortcuts |
Description |
Object Related Track |
O |
Display all the related tracks of the selected object. |
Show Collect Clip Track |
Q |
Show the Collect Clip track if they’re hidden. |
Show Transform Track |
T |
Show the Transform track if they’re hidden. |
Show Motion Track |
M |
Show the Motion track if they’re hidden. |
Show Reach Track |
R |
Show the Viseme track if they’re hidden. |
Show Viseme Track |
Z |
Show Expression Track |
E |
Show the Expression track if they’re hidden. |
Show Link Track |
L |
Show the Link track if they’re hidden. |
Show Visible Track |
V |
Show the Visible track if they’re hidden. |
Show Material Track |
S |
Show the Material track if they’re hidden. |
Show Sound Track |
D |
Show the Sound track if they’re hidden. |
Show Spring Track |
I |
Show the Spring track if they’re hidden. |
