The Edit menu on the main menu bar contains all the commands for
manipulating 3D entities in the scene.
Undo / Redo (Ctrl + Z / Ctrl + Y) |
To undo or redo the last action. |
Delete (Del) |
To delete one or more selected objects. |
Select / Select All (Q) |
Move / Rotate / Scale (W / E / R) |
To transform the selected objects. However, the Scale tool does not work on characters. |
Multi-Duplicate |
To duplicate a prop into multiple copies with identical settings. |
Align |
This item contains a sub-menu with two features.
Link |
Attach |
This item contains a sub-menu in which two features exist.
Merge |
This command merges a set of parent-child props that is composed by the Attach command into a single prop. |
Visible |
This command sets a key or keys to show or hide one or more 3D objects. |
Camera |
Terrain Snap |
This item contains a sub-menu with three features.
Bake All Substance Textures |
This command bakes the substance texture to the eight channels of the prop. |
Real-time Smooth |
This command basically tessellates a prop with low polygons into a prop with 3-time-higher polygons. |
Open Mouth |
This command opens the mouth of your character. |
(Ctrl + Shift + P) |
This command displays the Project Settings panel for you to adjust the Time Unit, Global Sound Settings, Global Physics Settings, 2D Background and shows the Information about the current project. |
Preference (Ctrl + P) |
This command displays the Preference panel in which you may adjust the authoring environment of iClone to your customized one. |
