The Basic Workflow from the Kinect Depth Camera to iClone
iClone offers the most affordable and intuitive motion capturing solution in the industry.
Now you can use your body to control virtual actors, in real-time, with motion smoothing optimizations.
Speed up your animations and create realistic-looking motions quickly, by literally controlling actors with your own body movements.
Flow chart for motion data capture
Microsoft's Kinect Sensor: Captures and passes human body motion data to the mocap device plug-in.
Make sure that the power supply of the sensor has been plugged
in properly. Mocap Device Plug-in FAQ.
Recommended H pose - This ensures the best knee results during motion data capture.
Note:
The benefits of H pose:
The Device Mocap Plug-ins can determine the best position of body joints for
better motion capture.
The infrared from the camera should not be blocked by any of your body parts or limbs.
Hold the pose and wait until the plug-in finishes the countdown. Now your motions can be converted into motion data and sent to the plug-in.
B. Receiving Data from the Device Mocap Plug-ins
Apply and select a character in iClone. It is highly recommended that you Deactivate the Foot Contact
feature of the character in order to receive the best foot motions from the Mocap Device Plug-ins.
Go to Animation >> Motion,
and click the Device Mocap button in the Modify panel.
Click the Connect button so that iClone connects
to the plug-in and starts receiving motion data from it.
Depending on the installed location of your Microsoft Kinect Sensor you may :
Local: If the Microsoft Kinect Sensor is installed on your local machine, then
choose this radio button.
Network: If the Microsoft Kinect Sensor is installed on another computer on the network,
then choose this radio button, type in the IP Address of the computer and then click the Connect
button again to receive motion data from the plug-in on that computer. It is useful when the other computer is faster than your local computer.
From the dummy panel, select the body parts that you intend to capture motions from. Please refer to the
Multi-layer Capturing section for more information.
Click the Preview button, and press the Space Bar to
preview your real human motions on the virtual
character (Shortcut: Space bar).
Click the Record button and press the Space Bar to
start recording (Shortcut: Alt + Space bar).
Note:
If you are using iClone with the Device Mocap Plug-ins by yourself, then you can
use the
Body Command feature to start, or stop the Preview, or Record
procedure remotely instead of pressing the Space Bar.
Adjust the Smoother slider value so that the captured motion will become smoother and eliminate jittering.
However, keep in mind that higher smoother values will require more system resources.
Please note that if you move you limbs closely, or overlap them, then this will cause occlusion with your torso, and the hands of the
virtual character may penetrate its own body. Please keep your limbs away from your body
with enough distance for optimized motion results.
Hands closely crossed in front of the body.
Character's hands penetrate the body.
Using the Mocap Device Plug-ins with Mirror Mode
By default, the character's body parts use the motion input from your body to move. Therefore, when the character is facing you
and you move your right hand, the character will also moves its right hand, which can sometimes be confusing,
especially when you need to interact with the props inside of the scene. For this you can work with the Mirror function.
Mirror = Off
Activate the Mirror box and then you may control the character as if using a mirror.
