The only iClone material setting that maps to the Indigo Glossy Transparent type is the Refraction setting. The mapped Indigo parameter is Exponent.
If you combine the settings described above with any reflection-related settings in iClone, such as Reflection Map, Reflection, Specular and Glossiness, then the mapping material will be Indigo Blend Material Type.
Low Refraction value in iClone |
Low Exponent value in Indigo. |
High Refraction value in iClone |
High Exponent value in Indigo. |
