Leveling the Virtual Floor Direction
During the Previewing or Recording process, you may occasionally find the virtual floor in iClone does not seem to align to the horizon properly, which can cause the character to move as if its on slanted ground, float in the air or sink underground. This is most likely because the Sensor has inadequately detected the real floor's location.
Use the Floor Adjustment feature provided in the Device Mocap Plug-in, and get someone to assist you in leveling the virtual floor direction.
Follow the standard workflow or
use the Body Command
to switch on the Preview mode.
The character may move in a slanted direction or float in the air occasionally.
At the Floor Adjustment section of the Device Mocap Plug-in, you will see three adjusting
sliders.
Move around where you are and have your assistant gradually modify the floor adjustment settings by observing the status
of the character and dragging the corresponding sliders.
Adjust the Front-Back Rotation slider.
Adjust the Left-Right Rotation slider.
Adjust the Height slider.
- After you have obtained the ideal settings for your floor adjustment levels, you may start to record your motions.
