Filtering Out Separate Motions from a MotionPlus File
MotionPlus files contain actor and accessory-related animations. When you want to re-use them, you can reuse and combine animations to a group of actors, or choose to separate and apply different parts of the animation.
Merging Data from Different MotionPlus File
  1. Here we have two actors; one is sitting and talking.
    The other one is running but mute.
  2. Export the first actor's entire motion range (body motions, voices and facial expressions) as a MotionPlus file.
    Please refer to the Body Motion and Facial Expressions section for more information.
  3. Select the second actor (in this case, the chimpanzee).
  4. Click the File >> Merge MotionPlus command from the main menu bar. Select the MotionPlus file exported in the previous step.
  5. You will be prompted with the filter dialogue box below. Activate the Facial Animation box to ensure that only the voice, lip-synching keys and the facial expressions in the MotionPlus are extracted and applied to the actor.
  6. You will see that only the first actor's facial animations are applied to the actor while the original body motions are kept.
