Setting Parameter Value
There are 4 methods to set values for the parameters in the Modify Panel.
Dragging Sliders
When there is a slider present in addition to the numerical parameter, you can drag it to adjust the value.
Clicking Arrow Buttons
You can use the Up and Down arrows to increase and decrease a parameter's value by one.
Typing into Numeric Fields
You can also focus on the numerical field, type desired value and confirm it by pressing the Enter key.
Utilizing Transform Tools
If you use the manipulation tools or transform gizmo to move, rotate, or resize an object, the value will automatically be updated in increments or decrements of 1.
Transform Hotkeys:
- Alt + Up/Down/Left/Right arrow keys: Move object by 1 unit on the X-Y plane.
- Ctrl + Up/Down arrow keys: Move object by 1 unit along the Z axis.
- Ctrl + Left/Right arrow keys: Rotate object by 3 degrees on the Z axis.
- Shift + any of the above hotkeys: Commands are increased tenfold (for faster transformation).
![Back to Top](../../../Resources/Images/top.png)
