Jumping from Path to Path
In iClone, you can create multiple paths in a scene for props and characters to jump to and from.
Create two paths and an object (in this case, a prop with motion).
Have the prop to move along a path (the red one) from the start point to the end point by setting Path Position Keys. Playback to view the
final result.
Go to the next time frame when the object moves to the end of the path.
- Make sure the object is selected, right click on the preview window and choose Path >> Pick Path from the right-click menu.
- Click on the start control point of the other path. The object will snap to the point instantly.
You will see a new key added to the Path Position (%) sub-track. - Follow the same method to have the object to move along the newly picked path.
- Playback to view the result.
